Maintenance on lifted Jeeps
Old Apr 5, 2010 | 03:17 PM
jay01th's Avatar
Default Maintenance on lifted Jeeps
I read in the installation kit that you need to re check bolt torques every 3k miles when you put a lift on your Rig. Are you guys doing this? And if you are doing this Which bolts are coming loose? I went with 295 70 17 tires.
Old Apr 5, 2010 | 03:19 PM
highoctane's Avatar
I only torqued mine after the first 3k miles. Never had to after that, and you shouldnt really need to.
Old Apr 5, 2010 | 10:34 PM
spinlock's Avatar
I retorqued my about 500 miles after installation (front track bar was slightly below its spec) and I inspect the whole suspension about every 2K. I used to check the torque on each of these inspections but it's been fine since I retorqued.
I also check the wheel spacers torque every time I rotate the tires.
Inspecting the suspension and torque settings only takes 30-45 min and really isn't a hassle if you keep your undercarriage clean. Yeah, I know some think that packing it with mud and rust is a badge of honor. Maybe so, but it makes maintenance much more difficult.
Old Apr 6, 2010 | 01:09 PM
jessmcquaid's Avatar
I checked mine after the first 500 miles and will also at 3000. It does not take all that long really.
Old Apr 7, 2010 | 07:35 PM
Weeds's Avatar
If you are going off road, it does not hurt to check every bolt and the fluids on your jeep on a regular basis. It is amazing what will work loose. It does not take very long and it does not hurt to just crawl around under your rig.
