Flat fenders
Old Apr 6, 2010 | 11:58 AM
drrex's Avatar
Default Flat fenders
I am buying a 4 door rubicon this week and I am wondering what size tires i can fit (with or without wheel spacers) if I put on flat fenders? Any thoughts? I am looking to fit 35's with the least ammount of lift possible. I loved the look of the mopar "lower forty".
Old Apr 19, 2010 | 01:11 PM
ghostryder's Avatar
pretty much any budget boost(2 inch spring spacers) will be good......you can run 35's stock but will rub fenders on any flex
Old Apr 19, 2010 | 01:13 PM
wayoflife's Avatar
JK-Forum Founder
sure, with chopped fenders or other flat fender setup, you should be able to run 35's with little to no rubbing.
Old Apr 19, 2010 | 01:49 PM
Gaidheal's Avatar
Saw a Jeep on PowerBlock TV the other weekend - had Bushwacker flat flares and the guy claimed it cleared 35's with spacers and no other mods.
Jamie
Old Apr 19, 2010 | 09:39 PM
rubydak's Avatar
I'm in the middle of doing something like that. Flat fenders, stock wheels with 1.5" spacers, 35" BFG km2s, Leveling kit no "lift". Should all fit.
Old Apr 19, 2010 | 10:06 PM
2xcapeIN's Avatar
From: Missoula, Montana. but currently JBER, Alaska
Yep, I agree! I did it to my 2000 TJ see:
35's don't rub at all after I choped the fenders, there are 1.25spacers installed also.
Still waiting for my JK to be shipped overseas, my lift an tires are already here! jus need the Jeep now!
Anyway hope this helps make up your mind.
Old Apr 20, 2010 | 06:11 AM
tslewisz's Avatar
Nice post, planman. Thanks.
Old Apr 20, 2010 | 10:39 AM
Gaidheal's Avatar
Originally Posted by planman
The Powerblock episode made clear there were rubbing problems in the rear fender well & that they were going to install a short lift with extended bumpstops to fix it in the near future.
Missed that - good catch.
Jamie
Old Apr 20, 2010 | 10:51 AM
chadsrub's Avatar
Default Re: Flat fenders
You can clear 35's no problem if you cut your fenders and a spacer. I am looking to only go up to 33's, so i do no need the lift. But, my local shop said to do a spacer lift if i went 35's. It was about a 2 hour job for me. I am getting better at it now that I have done a few of them. Check it out. I have a video to of more of the underside.
Old Apr 20, 2010 | 01:01 PM
Stephens2r's Avatar
I am running 315x75R16 BFG KM2's on Black Rocks 16x8 wheels with 4.25 backspacing with no lift. I have the Xenon narrow flares. I haven't run it disconnected yet, but there is no rubbing while connected so far. This is temporary for me, but I can see it working long term if you don't off road too much.
