Quick Franken lift ?
Right now i have a RC 2.5 spacer lift
instead of taking it off and buying a new "bigger" "better" lift, is it possible to leave it on and buy the teraflex 2.5 coil lift and add it too it??
if so i know ill need:
Longer shocks
sway links
Upper control arms for caster (??)
track bars
Bump stops
Please someone chime in if theres other things needed or if this wouldnt work as an option
Thanks Bryan
Longer shocks
sway links
track bars
Bump stops
Thanks Bryan
it depends on a 2 door 3 inches of lift will do both the front and rear i beleive on my 4 door i have a 3 inch teraflex and have ripped the boot on the extension part of my driveshaft and plan to replace it very soon
btw its my front driveshaft that the boot is torn
The Faq's are generally a decent place to start...
Q: What are all the components that I will need with a 4" lift?
Q: What is Caster? How much do I need?
Then move on to the DIY alignment write-up.
