Steering Darts around with Teraflex Arms
Old Apr 9, 2010 | 07:42 AM
lhracing's Avatar
Default Steering Darts around with Teraflex Arms
I installed a set of 8 Teraflex control arms, set the caster to 5.5 degrees but now the Jeep darts around on the freeway. Has anyone else experienced similar problems? Any suggestions on how to fix it?
Old Apr 9, 2010 | 07:52 AM
Piginajeep's Avatar
you need to adjust your caster a little more
Old Apr 9, 2010 | 08:23 AM
CitadelJeep04's Avatar
Which way? I'm curious too.
Old Apr 9, 2010 | 08:24 AM
wayoflife's Avatar
JK-Forum Founder
are you sure you added positive caster and not negative?? 5.5 of negative caster will really screw you up. positive caster will have your pinion dropping to the ground.
Old Apr 9, 2010 | 08:25 AM
wayoflife's Avatar
JK-Forum Founder
this should help you out
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Apr 9, 2010 | 08:28 AM
Piginajeep's Avatar
awh, I didnt catch that....
Old Apr 9, 2010 | 09:54 AM
lhracing's Avatar
Positive 5.5 degrees, pinion is pointing down (not up)
Old Apr 9, 2010 | 10:54 AM
TEEJ's Avatar
Talking
Generally, more caster tracks straighter, but has slower turn-in.
Darty handling is merely excellent tun-in.
So, generally, you add positive caster to reduce dartiness.
Plan B - if the dartiness is in response to the suspension compressing/extending, as in reacting to bumps, then its more likely bumpsteer than caster at play.
Old Apr 9, 2010 | 10:56 AM
mkjeep's Avatar
Lengthen 2 turns, report back.
Old Apr 9, 2010 | 11:14 AM
lhracing's Avatar
I will give this a try this weekend, thanks.
