AEV's Procal??????
Old May 22, 2010 | 09:19 AM
azrwilkinson's Avatar
Default AEV's Procal??????
Just wanted to know...I have heard different stories. Is the procal VIN encoded or not. Really looking for a cheap way to calibrate speedo and gear change. Any help is appreciated!
Old May 22, 2010 | 10:03 AM
wayoflife's Avatar
JK-Forum Founder
yes, they are vin locked once they are used. the only way you can use it on another jk is to return the jk it was used on back to stock
Old May 22, 2010 | 02:17 PM
josh_jacklyn's Avatar
yes that is correct sir.. it's not like they're too expesive considering all they do. since i installed mine i love it! shift points changed and are better. getting better gas milage. and we now have day time running lamps. all in all probably the best 150 i have spent on the jeep so far.
Old May 22, 2010 | 04:28 PM
jk20084p's Avatar
And no more chimes for tire pressure with my Procomp wheels without pressure device !! Just set it to 0 pounds
Old May 22, 2010 | 06:15 PM
nthinuf's Avatar
If you buy it used, be sure to verify that they have in fact Restored back to stock. It'll save some headaches...
Old May 22, 2010 | 06:26 PM
tslewisz's Avatar
Everyone's right. It's a very useful, inexpensive tool. Mine has done what I've asked of quickly and simply. This answers your question at the source:
http://www.aev-conversions.com/produ...tech_specs.php
Old May 23, 2010 | 06:05 AM
Thanks everyone for the input. I did see some for sale on the forum and wasnt sure. I will just have to save up.
Old May 24, 2010 | 04:05 AM
jk20084p's Avatar
Its Ok to buy it used, as said previously, just make sure the seller restored original settings using the Procal before buying it.
