inexpensive rims?
x2 on the soft 8's. They run less than $100 per wheel. Pro Comp series 7069's are also just a little over $100 per wheel. Both listed at those prices on quadratec. I haven't looked around for any other sites
Procomp Rock Crawlers below are $55.99 ea. I got mine last year for $52.99.
Rock Crawler Series 52 Gloss Black Powder Wheel
15x8, 5 on 5 Bolt Pattern
Backspace = 3.75 in.
Max Load = 1600 lbs
Finish = Gloss Black Powder Coat
Max Load = 1600 lbs
Look at 15x8 steel wheels from summitracing.com for $43 each (get 3.75" or 4" backspaced wheels).
h ttp://www.summitracing.com/search/Part-Type/Wheels/Wheel-Bolt-Pattern/5-x-5-in/Wheel-Diameter/15-in/Wheel-Width-in/8-00-in/?keyword=cragar&Ns=Price|Asc
Then, you can buy 35x12.50R15 tires for about $200 or less each.
For center caps, you can either go without, or you can buy any 3.3" diameter cap:
h ttp://www.summitracing.com/search/Part-Type/Wheel-Center-Caps/Section/Tire-Wheel-Accessories/Diameter-in/3-300-in/?Ns=Price|Asc
For lugnuts, you can reuse your stock lugs, or you can buy 1/2 -20 RH, 60 degree conical seat nuts:
h ttp://www.summitracing.com/search/Part-Type/Lug-Nuts/Thread-Size/1-2-20-RH-in/Lug-Nut-Seat-Style/Conical-seat-60-degree/Wrench-Size-Required-in/3-4-in/Open-End-Design/No/?Ns=Price|Asc
Are there any drawbacks changing from 17" wheels to 15"?
I got a set of 5 Procomp 7069's in black this weekend for 650 total. 4th of July sale. I went with the 17's so I could run my stock BFG's until those wear out. I think they look a little better than 15's anyway. But I know you can get those in 15" for like 90-sumth'n $.
not trying to hijack, but would it be ok to run a 10" wheel with a 12.5" wide 35 just to keep from buying a new set of wheels when the time comes for 37's? i know it increases the likelihood of losing a bead when aired down but other than that are there any reasons why this shouldn't be done? i'm going with super cheap steelies but i would like to avoid buying two sets
