rear TF trac bar brackets/ JKS coil mounts
Old Jul 8, 2010 | 09:11 AM
sktdarkstar8's Avatar
Default rear TF trac bar brackets/ JKS coil mounts
does any one know if the TF rear trac bar bracket that comes with the 4in lift kit will work with the rear axle jks adjustable coil mounts?? i looked in the rear and it would be a close call.. i would like to know for certain otherwise should i just have someone weld on new TF or currie coil mounts?
