Popping Sound?
Old Jul 12, 2010 | 03:22 PM
mrFoSure's Avatar
Default Popping Sound?
For about a month or so now when I go from a dead stop and accelerate right at the point I start to move there is a popping sound just one "pop/click". Any ideas? Really freaking out and any help would be appreciated thank.
Old Jul 12, 2010 | 03:23 PM
stonewhite's Avatar
possibly the steering clunk issue? You might want to do a search on it.....just a thought
Old Jul 12, 2010 | 03:24 PM
Full-Traction Suspension's Avatar
Former Member
try and re-torque all your suspension bolts to spec while the jeeps on the ground.
this is usually the the cause of suspension pop. it doesnt hurt to grease everything either.
Old Jul 12, 2010 | 03:48 PM
mrFoSure's Avatar
Not bad ideas. This might help, its sounds like its coming from the rear. Also this came to my attention after I had a TeraFlex lift installed, can't remember if I had this sound prior to the lift or not and also it seems to be getting worse. Thanks. Total non mechanic here and learning as I go, recently started changing my own oil and normal maintenance so how would one go about torquing the suspension and greasing? Thanks in advance!
Old Jul 12, 2010 | 04:22 PM
Former Member
its very easy. Buy yourself a good torque wrench from sears and a grease gun for zerk fittings.
Located your fittings on your suspension, and grease away.
here's a chart for torque specs
http://project-jk.com/jeep-jk-write-...orque-settings
Old Jul 13, 2010 | 04:17 PM
stonewhite's Avatar
Does a stock JK have any grease fittings on it? I've looked and haven't located any....plus the place I get the oil change done at says it has none. Is that right?
Old Jul 13, 2010 | 04:25 PM
Former Member
right the stock JK does not have grease fittings on the suspension.
Old Jul 13, 2010 | 07:10 PM
mkjeep's Avatar
Judging from the pics on the other thread of your incorrectly installed rear links and brakeline brackets, I'd start there.
