How long are vent lines on Tcase and Front axle and where do they go?
Old Aug 10, 2010 | 04:37 AM
RyanBlack321's Avatar
Default How long are vent lines on Tcase and Front axle and where do they go?
Need some help, the jeep dealer cant seem to anser my question.
How many feet approx. of 5/16" hose goes from the front axle vent tube to its ending location and does it end in the front fender?
Same for the Tcase vent line, how long and where does it end?
Also, has anyone used the river raider vent line kit? It extends the lines and runs it to the factory air box?
Thanks
Old Aug 10, 2010 | 04:44 AM
rinkishJK's Avatar
Default Re: How long are vent lines on Tcase and Front axle and where do they go?
the front vent ends at the top of the spring perch on driver side.. where the top of the shock bolts in. When I did mine I just got some more hose and a vaccum fitting and extended mine up into engine bay in top driver corner next to brake cyl. The tcase I believe is ran up trans bell housing close to firewall and sits there. The rear axle is just inside plastic liner on rt rear. That one I ran up behind pass tail light in the big open spot.
Sent from my Droid
Old Aug 10, 2010 | 05:17 AM
GON WHLN's Avatar
For the front and rear diff breathers I jst bought 2 sections of 1ft hose and 2 male to male pass thru's and 4 hose clamps.
Ran them the same way the other guy did.
