new guy with a bumper question
Old Aug 13, 2010 | 06:42 PM
ecmo92's Avatar
Default new guy with a bumper question
Hello all, Im a proud new owner of a new mountain edition unlimited. Well, with under 3k miles on it, someone decides to hit the front bumper. I was planning on doing a lift for my first mod but looks like it might be the bumper first. Going through all the bumpers out there my wife really likes OCF full width http://www.quadratec.com/products/12126_0001.htm
Is this gonna drop the front with the extra weight? I was planning on the tf 2.5 bb, but should I now plan on coils too? So far we love the jeep and but dunno if we'll ever be REAL off roaders. Im secure in my manhood to admit it But we do want this sucker to look as good as we can make it.
Old Aug 13, 2010 | 06:51 PM
jmoschgat's Avatar
I have heard of an aftermarket front bumper sagging the front of a JK lifted with a BB. So you should think about also adding coils. I have the Rough Country 3.25" lift with an aftermarket bumper and have no sag. You could opt not to use the .75" spacers included with this lift if 2.5" was all that was desired and you would get a pretty complete 2.5" lift.
Old Aug 13, 2010 | 08:54 PM
ArrowheadRay's Avatar
With that bumper you will get some sag with a 2.5 BB. If you're going to lift it, go with a coil lift. You may still need to add a 1/2 to 3/4 inch spacer up front depending on the spring rate of the coils that come with your lift. If you want to add the bumper and don't want to go with a complete lift, you can always add the JKS ACOS adjustable coil over spacers up front only. They're adjustable from 1" to 4" and will level the JK out real nice
Old Aug 13, 2010 | 09:07 PM
JKCliff's Avatar
My PJ bumper dropped the front (w/TF BB) 1/2". I took the rear spacers out and it leveled out nicely... I ran 315/75R16 on 16X8's without any contact... if you need additional room cut your fenders or go with some flat style fenders... Just my opinion...
Old Aug 14, 2010 | 05:45 AM
SargeW's Avatar
I still run the stock bumper, but have added a Warn 9500Ti, Rugged Ridge mounting plate, and a Blue Ox tow plate. All of which weighs in at around 200 pounds. It dropped the stock suspension about 3/4 to 1 inch. I added a set of Rancho leveling coils and recovered the sag, plus took out the factory rake. I now sit level or just slightly up in the front and the ride was much improved over stock. It was around $200 for the coils and install. I was even able to keep the stock shocks. No issues in over 25K miles.
Old Aug 14, 2010 | 05:57 AM
Sapper12b's Avatar
As far as front bumpers go I was eye balling the LOD, AEV and the ARB. Take a look at them to get a good feel for all the different styles. Plus there is a thread here where people have posted pics of their LOD bumpers .... Pretty awesome
Old Aug 14, 2010 | 07:46 AM
ecmo92's Avatar
How bad will it be with stock suspension? It'll be a bit before I scrounge up the cash for the lift.
Old Aug 14, 2010 | 08:12 AM
funwthmud's Avatar
I added an aftermarket bumper while still stock and i got some sag. here is a link to the one i added, so you can see mine would weight less than the one you want.
http://www.quadratec.com/products/12148_100.htm
I should note that all the front sag went away when i added my TF 2.5 coil lift. I do expect to have to make adjustment when i add a winch.
Good luck in your choice
Old Aug 14, 2010 | 08:23 AM
bhardy's Avatar
You know, i rarely see any one talk about the Fab Fours Bumbers, I think they look sick. They make a full width one too.
I think sag wouldn't be an issue, unless you stuck a 100lbs wench on the front.
ID:	81972   Click image for larger version
Old Aug 14, 2010 | 12:49 PM
JKRINGO's Avatar
Hold on! How bad is the damage, the skin on the oem's get dents if you look at them the wrong way. If that is the case you most likely will be able to pull the dent out .
