Squeak Squeak..........
Old Sep 9, 2010 | 08:49 PM
fitzb's Avatar
Default Squeak Squeak..........
Anyone have advice for suspension squeak? quick fix????
Old Sep 9, 2010 | 09:13 PM
mkjeep's Avatar
Lube it....
Old Sep 9, 2010 | 09:23 PM
fitzb's Avatar
lots of lube is always good, oh yeh back to the jeep.......
didn't help
Old Sep 9, 2010 | 11:32 PM
warlord's Avatar
didn't help
then something else must be squeaking
you can pin it down if you can identify when it squeaks
does it squeak when turning?
acceling/ braking?
potholes/ speedbumps?
flex?
Old Sep 9, 2010 | 11:52 PM
JKBANDIT55's Avatar
make sure everything is tight!
Especially the nut and bolt on the bottom end of your shocks! also check your brakes and rotars, thats whats squeaking on mine right now.
Old Sep 10, 2010 | 06:40 AM
sshifflett's Avatar
mine just started sqeaking over pot holes and speed bumps.
Old Sep 10, 2010 | 08:05 PM
fitzb's Avatar
always on turns and bumps, I can't pinpoint it !!!!
Old Sep 10, 2010 | 11:33 PM
No1AP's Avatar
Quick thought, because mine was squeaking like crazy. One of my front springs became unseated from the perch at full droop and spun a few degrees, just enough to set the bottom of the spring at an angle that leaned my sping into the frame. When I went over a bump, or accelerated, or stopped, or started it, or looked at it... well you get the point... Just a thought.
Old Sep 11, 2010 | 05:59 AM
oregon signs's Avatar
my springs and bushings squeak alot. graphite spray helps, but dust kills it after a trip.
