Shocks for Everyday Road Travel
Guest
Posts: n/a
Looking to replace the OEM's on my 2010 Jeep Sahara. I know there are many opinions out there, but I would like your opinion on the shock availability for a soft to medium ride. Thanks in advance. Also replacing steering damper.
You don't need to replace the steering damper with stock tires
Unless you are doing more than a budget boost and want shocks for "everyday road travel," why upgrade from factory? Unless you plan on doing some sort of lift that's 2" or more and plan to hit a rough jeep trail or go rock crawling, I'd save your money for other things.
Most aftermarket shocks are designed for 2" lifts or more. In general, I have never had a single problem with any Teraflex product to date on both my old TJ and JK.
cant help with shocks for factory height. maybe just get some rubicon take offs??? the only reason to replace the stock steering stabilizer is if its been smacked on something and/or leaking. if thats the case, the TF stabilizer is nice and the price is great.
Even my wife noticed that her Sahara rode better and drove better after I installed the Monroe shocks.
If you want a better handling vehicle you made the correct choice. If you want a softer ride (hell it's still a Jeep) OME. I personally prefer a better handling vehicle on & off-road. I went though quite a few different sets of shocks (Rubicon w/extenders, Teraflex, Fox & OME) prior to settling on the Bilsteins, they are hands down the best set for my needs/wants.
