Evap skid OR Evap relocation...
Looking for some opinions here!
I am leaning toward the poison spyder evap skid, however I am open to relocation if it is just as easy.
I would like to know what everyone has done and why, so please post!!
Any details about your mod would be greatly appreciated as well.
Thanks
Thanks
Relocated it without buying anything...only issue was the heat shield we made to protect it wasn't good enough and I burned two holes in it and had to replace it...really would do it all over again...well except I'd have built a better heat shield to begin with. (relocated muffler at the same time so that's why the need for a heat shield)
I suggest relocation. I relocated it and only spent $6.02
I took the bracket it is mounted on and cut the long end off. I shortened that end and welded it back the the bracket so that both ends are even. Then I purchased some 5/8" heater hose and relocated it. Fit bitchen.
I got skid row skid plate and have had no issues. The skid doesn't see much action and I play on rocks. It's more of a safety net mod. My lower control arm skids, diffs and gas tank skid see all the action.
I put the skid on. didn't want to risk warranty issues. took it wheeling pretty good and also my control arms took the action. Looking to by some plates for those.
Thanks
Thanks
