Problem with Front Shocks Bushings after Teraflex leveling kit install
Old Nov 27, 2010 | 08:40 AM
dxfiles's Avatar
Default Problem with Front Shocks Bushings after Teraflex leveling kit install
Just noticed some metal clanking up front in the last couple of days...discovered that my top shock bushing on the drivers side is gone the one on the passenger side is torn up.
Installed the Spring Leveling kit a few weeks ago...it did not come with shock extensions and did not call for them....but could this be the issue?
Please help--- at this point I am stumped???
Please advise if you have any ideas..
Man...kinda a scary..
Joe
Old Nov 27, 2010 | 08:51 AM
dxfiles's Avatar
The Part from the Jeep Parts Manual is called
part # 52060430AD 2 J, T, U 72, 74 GROMMET, Shock AbsorberUpper
This is what was missing on one side and torn up on the other..
Thanks
Joe
Old Nov 27, 2010 | 09:52 AM
dxfiles's Avatar
Bump for Urgent ideas!!!
Old Nov 27, 2010 | 01:17 PM
Northridge4x4's Avatar
Sponsoring Vendor
My only guess is that the shock was not put on properly after the install , but that is just a guess.
Old Nov 27, 2010 | 01:32 PM
dxfiles's Avatar
Dave---When I installed them was very straight forward...is it possible that I need the shock extensions?
I am getting some new parts tuesday...but I am afraid it will just happen again?
Joe
Old Nov 27, 2010 | 01:56 PM
Sponsoring Vendor
Is the nut and washer still on the upper shock and the bushing gone?
Old Nov 27, 2010 | 03:59 PM
dxfiles's Avatar
yes completely on the drivers side and on the passenger side it is ripped up and about to go....
Joe
Old Nov 27, 2010 | 04:06 PM
Sponsoring Vendor
Hmm interesting I am not sure what the deal is then . I will take a look at a few things on monday and get back to you
Old Nov 27, 2010 | 04:11 PM
RAINSTATEBEAR's Avatar
Did u install it washer bushings bushing washer nut? My friend installed mine the wrong way and they came loose he put bushing washer bushing washer nut... Hope this isn't too confusing.
Old Nov 27, 2010 | 04:34 PM
dxfiles's Avatar
Yes---in the order you said.... washer...bushing...bushing...washer nut.
I have been off road quote a few times since install and disconnected twice...
i was wondering if it could somehow pull down hard enough on the shock to shred the top bushing???
Joe
