Problem with superior axels 35 splines arb rd157
Old Nov 27, 2010 | 02:12 PM
JK GABY's Avatar
Default Problem with superior axels 35 splines arb rd157
The axles are side specific
Old Nov 27, 2010 | 02:21 PM
Joisey's Avatar
well duh
Old Nov 27, 2010 | 02:47 PM
Northridge4x4's Avatar
Sponsoring Vendor
Shouldn't be they should both be the same length I am pretty sure because the arb has centered coss shaft
Old Nov 27, 2010 | 08:54 PM
JK GABY's Avatar
Well the problem is the driver side does not enter all, it stays about 1/8 out .To surprise me I going to change sides if not fit ? CUT/SHOP.
For Knowledge of the people ARB 157 and Yukon Gears you need to cut the ring gear bolts just a bit Click image for larger version
ID:	105358[ATTACH]Click image for larger version
ID:	105358[/ATTACH] This bolt (1/2-20X1) shows the tread damage by reaching the bottom of the ring tread
Cut about 3/16
