what gears for 37x1350x17?
Old Nov 28, 2010 | 09:33 PM
maroon jk's Avatar
Default what gears for 37x1350x17?
I got a 07 sahara 4dr 6spd with a 4" lift with 37 tires. what should I re gear it to? And how much does it cost? And if I put back on stock tires after re gear, what will happen??
Old Nov 28, 2010 | 09:38 PM
Abacabb's Avatar
https://www.jk-forum.com/forums/show...276#post211276
Old Nov 28, 2010 | 11:16 PM
nthinuf's Avatar
You could try opening the 'other' what gears should I run with 37's thread that is right here on the first page. Might find some useful info there...
Old Nov 30, 2010 | 03:27 AM
Marauderer's Avatar
Thanks for the charts and the link to the FAQ's
Old Nov 30, 2010 | 07:30 AM
wayoflife's Avatar
JK-Forum Founder
as the gear chart will tell you, 5.38 is the ratio that you'd want but, depending on the kind of wheeling you do and how hard you play, i might recommend going with 5.13's as a 5.38 in a dana 44 has a really small pinion.
