D30 outters on D44 axles?
Old Dec 1, 2010 | 06:01 AM
mr_natural78's Avatar
Default D30 outters on D44 axles?
What exactly in interchangeable between the two? The complete outter? (spindles? ball joints? unit bearing assembly? brakes?
Thank you.
Old Dec 1, 2010 | 06:28 AM
ronjenx's Avatar
Ball joints, knuckles, unit bearings, all the same on JK D30 and JK D44.
Regarding the brakes parts, though, there are two different part numbers for each part.
One is coded (BRY) in the description column, the other is coded (BR6).
The dealer parts guy couldn't tell what the difference is. He can look up parts only by VIN.
He looked up mine, which showed the brake parts as coded (BRW), but the part number was the same as the one coded (BRY) in my parts book.
I'm pretty sure you can transfer everything though.
