600 mile road trip, I need positve caster.
Old Dec 1, 2010 | 05:49 PM
b4tn's Avatar
Default 600 mile road trip, I need positve caster.
The plan was to eventually get adjustable control arms after my lift and tires as $$ came available. But after spending 600 miles at highway speeds of 50-80 my knuckles and wrists are literally sore from holding the wheel straight. So on a budget , but not willing to skimp... Which control arm set is a good replacement? And can I do a pair at a time? Say front lowers first, rear uppers later, and so on. And which order would be best to do in "stages"?
Old Dec 1, 2010 | 05:53 PM
dlincoln91's Avatar
i like curries,teraflex, and rockkrawler
Old Dec 1, 2010 | 06:22 PM
Robar's Avatar
There are a bunch of good control arms. Currie, Teraflex, Full Traction, JKS and a bunch of others. And yes, you can start with the front uppers and work your way around if you want.
Old Dec 1, 2010 | 06:34 PM
nthinuf's Avatar
No profile. How much lift do you have?
<3 inches, you can get away with front uppers. (less expensive than lowers, but do not have the range of adjustability of lowers. Good for smaller lifts)
>3 inches, you are better off starting with the lowers.
Then add the rear uppers.
You will also want to crawl underneath and take a look at your driveshafts. If either is already spitting grease, you will want to start with the control arms for that end to go with the new driveshaft...
Old Dec 2, 2010 | 09:28 AM
iwantaJK's Avatar
I'm awaiting a set of Teraflex front lowers. I'm doing a 1,000 plus mile roadtrip in Jan and need caster BADLY!
