Painting grill
Originally Posted by enzo319
Matt89 - Did you sand down ur grill 1st? I was thinking of using that same color paint as u after I bedlined mine.
-Use fine grit sandpaper
-wipe off dust with tsp or some other cleanup remover
-spray 1-2 coats primer
-2-3 coats of color or bedliner
Bedliner on my grill it is flat black right out of the can no need to paint over it. I picked mine up at the local napa.
I used VHT nightshade to tint the turn signal lenses
And yes you have to sand first then prime then paint. It won't hold if you don't follow these steps
