BFG KM2 33x12.5 R15 + MB72 on OEM spare holder
Old Mar 17, 2011 | 09:08 AM
MasterG's Avatar
Default BFG KM2 33x12.5 R15 + MB72 on OEM spare holder
Hi guys.. Just bought 5x BFG KM2 33x12.5 R15 with MB72 wheels. I've also bought the "Off Camber Fabrications Spare Tire Reinforcement Kit". I'm wondering how the spare will fit in the OEM location ??
33" doesn't seem to be a huge "improvement" in size but the 12.5" + MB72 getting me worried.
I'm sure that i'm not the only one with the same setup so guys can you hint me ? I'm going to install these in a couple of hours. Do this setup will fit or am I going into trouble ?
I know that those tire/wheels will fit on the JK... just "curious" for the spare.
thanks !!
Old Mar 17, 2011 | 09:34 AM
MasterG's Avatar
The new wheels should have more backspacing so it may sit a bit further out from your jeep. The weight should be negligible since the rim isn't a ton bigger and the tire is just a touch taller and a little wider than 255s with 17s.
The new wheels have a lot less backspacing than the OEM. 3.75 VS 6 for the OEM. but maybe i'm wrong with the "6" from the OEM but they have surely less than the OEM. So maybe the spare tire will touch the tailgate or something ?
Old Mar 17, 2011 | 09:48 AM
speed2005's Avatar
wow 3.75? Those will stick out a lot!
Someone correct me if I am wrong but isn’t the optimal JK backspacing 4.5 or 4.75?
Old Mar 17, 2011 | 10:31 AM
Kmack84's Avatar
You'll be fine man... I have a similar setup on mine but with Duratracs.. It Does obviously stick out further then stock but not that much more..
Old Mar 17, 2011 | 11:23 AM
nthinuf's Avatar
4.5ish is to clear a 35x12.50 with no rubbing inside the wheel well. But, he ordered 15's. 15" rims will need the 3.75 backspace to clear the brake calipers.
Old Mar 17, 2011 | 04:36 PM
MasterG's Avatar
Hey all !
Everything works fine. All new tires and wheels installed and they look badass.
And you're right for the spare.. I think I've miscalculated the backspacing or inverted something.. The new spare is installed and YES he stick out more than the OEM one but thats not a problem. I ordered the Daystar extension because you were right too, the OEM do not touch the new tire at all. I ordered the spare tire reinforcement kit too.
Thanks for your help !! See you on the trail !
Old Mar 17, 2011 | 06:37 PM
XStream's Avatar
I used the
Off Camber Fabrications Spare Tire Relocate Bracket
Warrior Products Third Brake Light Bracket
for my 35 KM2
With No complaints
Easy Install once I figured out the reinforcement brackets
It is something I would recommend for an oversize spare setup
I have had it on for 4 months now rattle or movement at all
Old Mar 17, 2011 | 06:41 PM
MasterG's Avatar
Originally Posted by XStream
I used the
for my 35 KM2
With No complaints
GREAT !
Nice to know..
Here's mine !
Cheers !
Old Mar 17, 2011 | 07:06 PM
MasterG's Avatar
humm.. I hope the "now" is a typo ..right ?
Old Mar 17, 2011 | 07:21 PM
MasterG's Avatar
MasterG, that looks really good. Looks like the tire fits right into the groove of the bumper too. Maybe that is jeep's way of telling us that we are supposed to be running 33s. That poor YJ next to you looks so small.
Thanks mate ! I've got this wheels/tires installed today. I'll take a couple more pictures tomorrow. Look very badass with those KM2 VS stock wheels/AT tires !!
That made the Jeep look really like a "Jeep".
