Chromoly Axle Shafts Need Help
Yes, Please give Dave a call, the customer service is outstanding and he will help you with what you need. I got my chromo shafts and many other parts from him
I would definitely recommend getting the chromo. For the front, it will have full circle clips which is a huge advantage over stock c-clips. For the rear, well, I have bent 2 stock D44 shafts at the flange, then finally replaced with chromo and no problems since.
I got my RCVs (front) and Superiors (rear) through David. Solid so far.
also - right from Northridge they can press the bearings & set up your new rear shaft so you can keep your old ones as spares.
