Lift - Leveling options for STOCK TIRES
I have a stock 2011 2 door JK Sport with 255 tires. I would like to add a inch or two of lift, and would like better articulation from it. I will be keeping stock tires due to my tire warranty that is 5 years free replacement.
I have seen the currie Long Travel kit, the TF Leveling kit, and the Old Man EMU kit.
Basically, I want to keep the same look (Maybe a inch of height addition) With the stock tires and added weight of front bumper, winch, and rock rails. I will be adding sway bar disconnects as well for better articulation.
This gets complicated as I would like to use OE Tires and keep the good road manners, safety, fuel mileage, and reliability. Thoughts and suggestions?
I have a 2 door Rubi that I put a front bumper and winch...with the 2" pucks it was level..
If you're just looking for an inch or two, X2 on the pucks or look at the Teraflex Leveling kit, or whatever it's called.
OME will add 3-4", but from what i've heard around here, it's a really nice product. I have the Teraflex 2.5" coil kit, and i got about 3" in the rear and 3.5" in the front.
EDIT: be sure to read the sticky about lifts. The 2-door has other considerations beyond the lift once you go over about 3" (like driveshaft). Other 2-door owners can speak from experience.
If your looking to keep stock tires...I would suggest the TF Level Kit
http://www.northridge4x4.com/proddet...155200&cat=272
Anything bigger than that, you will have some serious fender gap.
