Control arm length TF 4"?
Can any 1 share with me the length of there control arms on tera flex 4" flex arm kit . i have a 4 door and im trying to center the axels to avoid the pinch seems and keep a good pinion angle thanks
I think you will get different answers. Tera says one length. Ppl on forum say another. I just installed mine and adjusted them until it lined up right. I still need to do some tweaking. My advice is follow the writeup. There is one on the forum already with the title with "how to install teraflex flexarms" . I would post it but on phone. Do the title search and you will see it
ya i set them 2 the inst. but they are wrong the axle is 2 far foward and thepinion is to the moon, i shortened the uppers, but i need to add about 1/2" to 3/4" to all the arms just trying 2 find measurment if anyone had them ill check the post 4 yours thanks.
If you dont mind shoot me the fronts also it never hurt to double check you may have a beter setup i have a lil bump steer and the alignment shop has the disco hitting the front left coil im not to happy im asking them for a refund and taking it somewhere else.
