Rocks stuck in rotor problem. Please Help
Old Mar 26, 2011 | 02:43 PM
medic_23387's Avatar
Default Rocks stuck in rotor problem. Please Help
I have MB72 15" rims with BFG KM2's and ever since I got them I can not drive down a gravle road without getting rocks stuck in my rotors. They will squeel and squeek so loud and it sound horrible and I have to take my tire off to get them out. Has anyone else had this problem as bad as I do? Is there any way to stop this from happening?
Old Mar 26, 2011 | 04:08 PM
Harbourone's Avatar
Are they stuck in between the wheel and rotor, or pad and rotor? If it's the wheel, a set of wheel spacers should push them away enough to clear the rocks. If it's the pad, I don't have a solution.
Old Mar 26, 2011 | 04:37 PM
A/C Guy's Avatar
Originally Posted by gint2
from what you describe it sounds like 15" is not the best option as there is not enough clearance between the rim & caliper/rotors.
The minimum rim size should be 16" for the JK.
Old Mar 26, 2011 | 04:47 PM
A lot of people run 15's on the JK.
Old Mar 26, 2011 | 04:49 PM
I have 3.75 backspacing and they alread stick out past my fenders so I really don't want to do spacers. Thanks tho
Old Mar 26, 2011 | 04:53 PM
Strong Bad's Avatar
A friend of mine had the same problem with 15" rims on his Unlimited. After going to 17s the problem was solved.
Old Mar 26, 2011 | 06:06 PM
nvrenuff's Avatar
This is answering my questions about 15" wheels, however how about an inexpensive aluminum wheel 17" with a confirmed 4" of backspacing?
Old Mar 26, 2011 | 06:09 PM
Tycho's Avatar
I get the occasional little stone stuck between rotor and pad. As soon as I hear the squeal I just stop put the jeep in reverse for a few feet and this normally clears it. Should work for stones stuck between rim and caliper also
Old Mar 26, 2011 | 08:56 PM
Just cause they fit don't mean they work well. I have seen spinners and 22" on JK, makes it just as wrong.
Search Quadratec Black Rock for an inexpensive alloy rim
Well I love the 15's with 35's I like the extra rubber when I air down. Smoother ride and grips the hell out of the rocks. Just my opinion. I'm am going to pull the wheels off tomorrow and by the end of the day I will think of a solution to clear the rocks I'll post back ASAP
Old Mar 27, 2011 | 08:14 AM
Good luck... Get creative like a dust shield and bend it backwards??? I would op for a larger rim, you only need 1/2 tire dia for rim size, ie 32" tire = 16" rim
Not going to get a bigger rim I just dropped 1600 on these new rims and tires a little over a month ago.
