Anyone running 33's on stock 17" rims??
Old Mar 29, 2011 | 07:14 PM
jesse0_0's Avatar
Default Anyone running 33's on stock 17" rims??
I seen many guys run 33's on a stock 17 rim. how do you find this works for you?
how large of a tire did you go? 33"-10.5?
what do you suggest i add.. bc isnt there rubbing issues if i dont add anything?
1.25" bodylift or
2.5 BB
thanks for all your info guys
Old Mar 29, 2011 | 07:24 PM
CrazyShadow's Avatar
I went with 285/70/17 KM2 (32.8X11.2), they are fine, no rubbing exept all full turn, they rub a little on the sway bar
To get rid of rubbing, add wheelspacers or add washers to your steering stop
Old Mar 29, 2011 | 09:24 PM
PoorDad's Avatar
My KM2's are advertised as 33 1/3, but mounted on the stock Moab rims at 30 psi, they are 32 inches. I had no rubbing anywhere at any time, but then again, they are the same width as the stock KM. The only thing I did not like about the 255/80R17 was that it is an E rated tire. It was OK with the stock suspension, but now with stiffer springs and shocks.......not as good. Still awesome off road when aired down, though.
Old Mar 30, 2011 | 08:46 AM
REDLINE217's Avatar
I'm running 33x12.50 on my JKU with a 2.5" lift and 1.5in wheel spacers and everything has been working out great on my stock 17" rims I would recommend some type of budget boost for 33s unless you won't do much wheeling, you will get some rub at full articulation, personally I don't like that some people don't mind it. No matter what I say for sure get wheel spacers the wheels line up with the fender perfectly and it looks way better than having your rims tucked in under the fender.
Old Mar 30, 2011 | 08:54 AM
Merlin4979's Avatar
295/70/17 Toyo MT's (about 33.5x11.5x17) on a Teraflex Leveling Kit w/ stock 17" wheels (& Spidertrax spacers) - a fantastic combo!
Old Mar 30, 2011 | 07:08 PM
jesse0_0's Avatar
very nice, looks really good!
how wide of a tire can I run on my stock 17" rims?
a stock 17" rim is 7.5" wide?
Old Apr 2, 2011 | 04:28 PM
JK-rook-E's Avatar
can i see pics of that set up please? cheers
Old Apr 2, 2011 | 06:09 PM
Merlin4979's Avatar
Plenty of people are running 35x12.5x17's on their stock 7.5" wheels with no problems at all. Just make sure that you've got spacers in there to correct the backspacing.
Old Apr 2, 2011 | 06:27 PM
SP77's Avatar
KM2 33x10 (255/80r17) and TeraFlex 2.5 budget lift. No rubbing at all.
