Front stock drive shaft question
Old Mar 31, 2011 | 09:28 PM
JKAbomb's Avatar
Default Front stock drive shaft question
I was just wondering if the front drive shaft still moves when the 4wd is not engaged? It may be a dumb question but I had to ask. The reason being I know mine is starting to fail as the cv boot is leaking. The angle is extreme from the 3.5" lift. I noticed some issues with the driveline a few months after the install. Can this cause binding and possible bucking motion when in first and second at low speeds and take off?
Old Mar 31, 2011 | 09:45 PM
nthinuf's Avatar
Yes, the front axleshafts, gears, driveshaft all move in 2wd, they are just not powered until you go into 4wd. Grab a wrench and pull that shaft off. It will help you diagnose the problem, and you don't want it seizing, especially at freeway speeds.
Old Apr 1, 2011 | 02:47 PM
JKAbomb's Avatar
Thanks. I will remove the front drive shaft this weekend and post the results and some pics,.
Old Apr 4, 2011 | 02:08 PM
JKAbomb's Avatar
Well, I removed the front DS and the front U joint is solid with no play whatsoever. The back cv joint is leaking a tad bit from the boot but nothing excess. This also seems solid. Drove for a bit w/o DS and was able to reproduce the bucking action. Had a friend come over and he check the play in my front DS. He can rotate back and forth and you can see my right axel u joint making noise and excessive play. Can this be The cause?
