Will a 33" tire, 15" wheel with 3 3/4" BS be OK?
2010 JK, no lift yet, future 2.5" lift. Will 33 x 12.5 x 15, wheel with 3 3/4" back spacing, fit OK without problems. I sincerely appreciate everyones advice.
THANKS!!!!!
FORGOT TO MENTION, 10" WIDE WHEEL
THANKS!!!!!
with the exception of your tires sticking out past the fenders, you should have no problems what so ever with 3.75" of back spacing. depending on the make and without any lift, you may have some rubbing on the fenders at a full flex though.
Originally Posted by jkd3624
With the lift ull be fine with the tires I would check the rim size mine because of the brake calipers I can't do 15in rims they won't fit I have a 2010 sport
I have a 2010 Sport Unlimited and im running 15s. I have no issues. As for what 15s fit I know ProComp wheels that are 15s with 3.75 bs and the 5x5 bolt pattern will fit. They made the to fit. I'm runnin 15x8 Soft 8s.
Just put mine on an hour ago, same exact specs as you, no lift. Fits perfect!
https://www.jk-forum.com/forums/show...heels-on-today!
