Lift Height & Caster Angle Question
Old May 6, 2011 | 04:34 PM
GeoJeep33's Avatar
Default Lift Height & Caster Angle Question
At what lift height does caster angle become an issue and require new control arms?
Reason I ask is that I have a TF 1.5" performance leveling kit waiting to be installed. The shop wants to do cam bolts(?) but I REALLY don't want to do that Not after doing some research into what that requires and the fact that they can loosen with moderate off-roading.
Can I get away without the control arms at this point with the TF 1.5" kit? Opinions? Thoughts? Comments?
Thanks in advance!
Cheers!
cory
Old May 6, 2011 | 04:54 PM
Robar's Avatar
You shouldn't need control arms with a 1.5" lift and you definitely do not want cam bolts.
Old May 6, 2011 | 04:58 PM
jlarso's Avatar
Yes.
You will lose about 1 to 1.5 degrees of caster.
This will put you at the low end of the recommended setting and steering will become more sensitive but it should not be a show stopper.
Lower end 2.5 in. lifts utilize the stock LCA's as a matter of routine.
I would not allow the shop to install cam bolts, they are not very robust specially off-road and they are not needed for 1.5"
Good luck
Jim
Old May 6, 2011 | 05:03 PM
nthinuf's Avatar
x3 on not 'needing' caster correction. Plenty of people are driving around with 4 or more inches of lift on stock arms. So add the lift and go drive it, and then decide.
Old May 6, 2011 | 05:05 PM
bigT's Avatar
Not needed, and cam bolt setup somewhat permanently modifies your control arm mounting holes on your axle. I have 4 inches of lift with stock arms and steering is pretty flighty and plan on moving to adjustable CA's in future.
Old May 6, 2011 | 05:15 PM
GeoJeep33's Avatar
Thanks all for the input. I am really hesitant to make permanent mods, such as those needed for cam bolts. I refuse to do it.
I like the advice of testing it and seeing what I need to do after the lift is installed.
I feel pretty stupid for not considering that in the beginning, it makes so much sense, seriously. What can I say, I am a master of common sense.
cheers
cory
