AEV 2" lift
Old May 9, 2011 | 07:22 PM
Dale36's Avatar
Default AEV 2" lift
Hello All,
Has anyone put on an AEV 2" lift? Thoughts? Pictures?
Thanks,
Dale
Old May 9, 2011 | 07:43 PM
jtjk's Avatar
nope. but i have only every heard great things about aev and their stuff
Old May 11, 2011 | 01:45 AM
Dale36's Avatar
Same here...
Old May 11, 2011 | 02:19 AM
trowand's Avatar
Thumbs up 2" Lift on JK
I've got an Old Man Emu 2" lift and I can tell you that with just 2" lift and the Bushwacker Flat Flares, you can honestly fit 35's or 36's. No Joke. It's amazing. I went with 34's and have a TON of room for more tire.
Old Dec 1, 2011 | 07:27 PM
vulcan classic's Avatar
Just added the AEV 2" spacer lift kit with shock extensions on my 2012 Rubi...
I'm runnin' 33x12.5-15 GY Duratracs on MB Razors, 15x8's
Old Dec 29, 2011 | 03:43 AM
Remington19's Avatar
i cant decide between this AEV spacer lift or the Teraflex
Old Dec 29, 2011 | 03:53 AM
ShakyJake's Avatar
Put the lift on our '09 Sahara 2dr but ditched the stock shocks and extensions from the kit and instead used proper sized Bilsteins. Awesome ride. I would highly recommend this setup. Allowed for running 295 Duratracs on Procomp rims no problem.
Old Dec 29, 2011 | 05:14 AM
dmwil's Avatar
I've got the AEV with BFG KM2's in 255/80/17. The whole package works great off road and on. I stuck with the Rubi shocks and extensions because I liked the way it rode and handled before.
Old Dec 29, 2011 | 05:52 AM
aristobrat's Avatar
TF's is 2.5" vs AEV's 2", but the parts look similar. If you're planning on adding heavier aftermarket bumpers later (which may cause your springs to sag), that extra .5" might be helpful.
AEV's looks to be $60 less expensive (using Quadratec's pricing).
Personally, I think AEV's front bump stops and shock extenders are easier to install than TF's, but it's not like TF's are super-hard to install. If you do go with TF, be sure to get a 16mm ratchet wrench to remove the front shocks -- you won't be able to fit a socket up there, and they take a gazillion twists to remove/reinstall, so you won't want to use a non-ratcheting wrench.
If you're installing this yourself, and you don't have much wrenching experience, I also prefer the diagrams in AEV's instructions, and how they include the torque specs. They also remind you to torque the control arms when the JK is back on the ground under its own weight, not while it's still on jacks.
Old Dec 29, 2011 | 01:41 PM
Thanks, I was just look at the TF leveling kit not the 2.5 lift.
