IS 4.75 BACKSPACING ENOUGH TO RUN 35s???
Alright i've got some Pro Comp 17x9 wheels with 4.75 backspacing and -6mm offset. I run a 33 12.50 17 right now on the with no rubbing issues with no lift. I have an opportunity to pick up some 315 70 17 BFG A/T's really cheap. Will my wheels have enough backpace to run these tires along with the OME HD lift without rubbing?
I think 5" backspacing would have been the limit, otherwise the tire would hit the fenders at full flex. With more lift it would be fine.
