next upgrade
Old Jul 24, 2011 | 09:08 PM
rubi08unlimited's Avatar
Default next upgrade
While i'm waiting on the closing for my house, I'm looking for inexpensive mods while I have free labor and use of a shop. best steering stablizer and relocation kit? It will need to be compatible with a Rock Krawler long arm lift. what setup should I go with?
Old Jul 24, 2011 | 09:10 PM
Hskr4x4's Avatar
FOX ALL THE WAY!
Hit up Gus in my signature for a great deal!
Old Jul 24, 2011 | 10:20 PM
Red Dog's Avatar
Originally Posted by Hskr4x4
FOX ALL THE WAY!
Does Fox makes good stuff but do they make a relocate bracket?
Old Jul 26, 2011 | 08:18 PM
aRe there any relo kits to stay away from or do they all do pretty much the same thing? I noticed that my steering stablizer got twisted this weekend so the braket is actually twisted all the way around the tie rod. Just coincidence that I'm in the market for a relo bracket and stablizer upgrade?
Old Jul 26, 2011 | 08:27 PM
centerfieldr162's Avatar
Jeep SWAG relocation kit and Bilstein steering stabilizer
Old Jul 26, 2011 | 08:31 PM
Is that compatible with the RockKrawler HD tie rod (larger in diameter) or can I re-use the larger ubolts supplied with the tie rod for use with the original stabilizer?
and where is the cheapest place to get the bilstien stablizer and relo kit mentioned?
Old Jul 26, 2011 | 08:34 PM
I'm not sure about the rock krawler tie rod and I wouldn't wanna tell you the wrong answer since I don't know, but I'm sure you could just use larger u-bolts I ordered my bilstein stabilizer from Gus at offroad warehouse and the stabilizer from Brett at Jeep SWAG/Dominion Offroad (jeepswag.com)
Old Jul 26, 2011 | 08:51 PM
FOX ALL THE WAY!
ouch! over 200 for just the stablizer! I found the teraflex for around 60. Can I get the bilstein for close to that? Bracket looks to run around 30 bucks but I havent found any place that has both as a kit. It would be nice to stay under 100. It looks like the swag kit re-used the same end that's on my tie rod right now which re-uses the provided larger u-bolts.
Old Jul 26, 2011 | 09:04 PM
If I remember correctly Gus was able to get me the bilstein stabilizer for around 80 dollars and the Jeep SWAG relo kit is 35 with free shipping
Jeep SWAG sells their relocation bracket and their own stabilizer for $100
Old Jul 26, 2011 | 09:52 PM
screaming lizard has the relo bracket and the teraflex for around 85 so the bilstien and bracket should able to be done as a kit for 100.
