Gear Ratio Question
Old Jul 26, 2011 | 01:49 PM
btruby's Avatar
Default Gear Ratio Question
What is the best gear ratio I should run on my 2009 JK Rubicon.
37', 13.50, 18 Nitto Mud Terrain
Dana 44's
2.5 Skyjacker Suspension lift
Auto Transmission
Do you think i can safely run on the stock 4.10 gears? I do have my computer set properly for the tires and gears with the AEV procal module as well.
Thanks,
Brad
Old Jul 26, 2011 | 02:00 PM
JayhawkJeep's Avatar
Veteran: Navy
It depends on your confidence on the strength of the 5.38's. Some like the power some think it is just a bit to small and go with the 5.13's.
Old Jul 26, 2011 | 02:11 PM
Lilahs Jeep's Avatar
I have a 6spd manual and went with 5.38. That way I can run 37's or 40's and run up and down mountain passes with no problem.
Old Jul 26, 2011 | 02:48 PM
nthinuf's Avatar
From an on-road performance perspective, 5.38's all the way. As Jayhawk mentioned, the only concern will be your opinion on the strength. Much more of an issue for the d30 than the d44.
Post #33 in this one is good reading:
https://www.jk-forum.com/forums/show...=1#post2147185
Old Aug 11, 2012 | 05:30 PM
btruby's Avatar
Default What is better
Does anyone have a prefence in ring and pinion companies. I am about to change my gears out to the 5.38's . My question is there any difference between G2 and Superior and which is better.... Thanks so much
Old Aug 11, 2012 | 06:05 PM
ghostjk's Avatar
I got Yukon Gears from Northridge4x4 and a master overhaul kit for cheaper then anywhere else I priced. I'm told ring and pinions are all the same
