Driveshaft slip shaft.... How much should be out
Old Jul 27, 2011 | 12:53 PM
rinkishJK's Avatar
Default Driveshaft slip shaft.... How much should be out
I think I might have another issue and I need opinions...
So I recently replaced all my Tom woods shafts u joints... Replaced em with Spicer greasables... Had to get needle fittings due to clearance.. so i went to my driveline shop, and they noticed my front shaft slip shaft had too much sticking out. He said the shaft was the wrong length.. now I think this might be from the fact I got these shafts with having just front lowers only. Since changing to all flex arms the axle is much more forward, and i think this is why my shaft is like this now.
So i could drop the shaft off to them, then they cut the end off and add a longer tube..
Is there any way the two pieces could actually slip apart when flexing??
Should I worry about this???
Here are pics of the front and rear.
I recall when I got the shafts there was a lot less space....
Thoughts please guys, I got the tatas run next Sat....
Thanks!!!
Old Jul 27, 2011 | 03:34 PM
rinkishJK's Avatar
Originally Posted by ECHO
WOW.. that is quite a bit out.. I would get that taken care of before you do any hard wheeling.. wonder how much is holding...?
Yea that's what I thought. When u say holding, u mean how much is left to come out ?? I would guess not too much...
I'm worried the shaft will separate.
Old Jul 27, 2011 | 03:38 PM
rinkishJK's Avatar
Yeah.. sorry that's what I meant.. how many inches are still holding the shaft on..
Ok. Yea I have no idea, but I'm guessing it should not look like it does. My friend said his coast rear shaft looks similar, but it's a coast, and it's a two door.
Old Jul 27, 2011 | 03:42 PM
rinkishJK's Avatar
Originally Posted by Freak
I've got quite a bit of blue showing on my Coast 4x4 rear driveshaft as well. Interested in others opinions.
I'm not sure if it matters with a 2dr, or 4dr, or front vs rear shaft. My gut is telling me there would be less, but idk honestly.
Also do u have all 8 adjustable arms?
Old Jul 27, 2011 | 03:46 PM
rinkishJK's Avatar
Can someone else post a pic of there front aftermarket shaft with flex arms??
Have you contacted Tom Woods to see.. I was just looking at some other shafts and they have quite a bit of spindle showing & showing allot of blue..
I'm not calling them. I already changed all the u joints in both shafts to spicer joints. Honestly I wish I had gone a diff route for the shafts, but that's another story..
Old Jul 27, 2011 | 03:50 PM
nthinuf's Avatar
Measure it. Pics can be deceiving.
I sent this pic to Tom and was told it was fine.
Old Jul 27, 2011 | 03:59 PM
rinkishJK's Avatar
Looks like mine is a lil bit more than yours.. just took these.
Old Jul 27, 2011 | 04:02 PM
fadeout's Avatar
I feel like that's a little more than you should and the powder coating job on those is horrible, I know you wheel but it shouldn't flake off like that.
rinkishJK's Avatar
I've painted it also.....
Old Jul 27, 2011 | 04:03 PM
fadeout's Avatar
whut? for the price they charge...that's BS.
