Loud metallic 'SKRONK!' sound when offroading
Old Jul 30, 2011 | 08:05 PM
blw's Avatar
blw
Default Loud metallic 'SKRONK!' sound when offroading
When I go off road I sometimes get a loud, harsh metallic noise, very sharp and short like SKRONK! underneath. I even noticed it today while in 4-low and backing up and turning, but generally it happens every now and then when in 4-low and going over rough terrain at low speeds (nothing extreme like rock crawling though). I guess I'll take it back to the dealer as they installed the Mopar 2" lift, but any clues what this could be?
I had the lift installed almost from the start, so it may not necessarily be the cause - I just never off roaded the rig before the lift. It's a 2-door 2010 with only 3K miles. Does anybody else get a sound like this offloading?
Here's a lousy cell phone pic of my rig:
Old Jul 30, 2011 | 08:08 PM
Croce's Avatar
I get what i think is the same noise when i go over speedbumps, not sure if that happens to you or not
Try checking out
https://www.jk-forum.com/forums/show...nd-noise-(long)
Maybe it might have some useful info for you
Edit: Double read your post and realized you said its when your in 4low..
Do you only hear the sound when turning? and in 4lo?
Old Jul 30, 2011 | 08:30 PM
Roaddog545's Avatar
Couldn't find skronk anywhere. Found Bam boof and splat......
Old Jul 30, 2011 | 08:33 PM
centerfieldr162's Avatar
Last time I went offroading, I heard a noise like that when I was in 4 low... Still don't know what it was
Old Jul 31, 2011 | 06:31 AM
blw's Avatar
blw
Try checking out
Thanks for the link, I'll check it out. The trail where I tend to hear it is quite rough, so I've always been in 4lo to keep the speed down. I'll see if I can repro it in just 2wd somehow...
Do you have a lift, too? I am wondering if it is the springs rotating or moving...
Old Jul 31, 2011 | 06:32 AM
blw's Avatar
blw
Originally Posted by Scooter Scott
When the stealership lifted your rig, did they put spacers on your wheels? All manufacturers call for spacers when you lift it otherwise you will hit vital components while wheeling
It's got factory wheels, just the 32" ones. I don't think I have the wheels turned very far when the sound happens...
Old Jul 31, 2011 | 06:35 AM
blw's Avatar
blw
Try checking out
His is a metal on metal clunking sound. This is more high pitched, like when you loosen a tight nut, only much louder.
Old Jul 31, 2011 | 07:31 AM
ride2099's Avatar
I got the same sound to when I go on 4lo everything is tight under the jeep I just put my new suspension and it still doing the same sound... firts time I was tought its was a bering wheel but after reflex It just happen after putting 4lo so I guess is in the front axle bering an pinion or maybe transfer case cause in 2wd no sound everything work good cause if you dont have a rubicon like me your front wheel lock only in 4lo maybe its the locker or that thing im not a expert
Old Jul 31, 2011 | 08:30 AM
Blakspire's Avatar
The backing plate behind the brake rotors loves to pick up rocks, which then make a high pitched metallic noise. If you can put up with it, usually will fix itself. I wouldnt describe it as a skronk, however.
Old Jul 31, 2011 | 08:50 AM
Yankee's Avatar
It is a short, sharp, metallic screech, metal on metal?
Mine does that sometimes hitting something like a sudden bump, but only once in a while. Has happened since 09 after the engine conversion.
I have never pinpointed it. Everything is tight and the suspension works fine, steering is stable at 80 mph. I always figured it might be the exhaust system since that was changed, hangers or heat shields, shifting (jumping) on the bump. It is for sure metal against metal movement though.
My noise is not related to 4-lo, can happen in 2wd.
