Gear 4.10 a quick question
Old Aug 18, 2011 | 10:58 AM
Mopahls's Avatar
Default Gear 4.10 a quick question
Over the winter I plan on re-gearing and just wanted to know about the right ratio I should go with. I don't plan on running anything over a 33in tire, but those are already a struggle because I have 3.21s now. Another question is will I have to change out the carrier when I move up in ratio?
Right now any advice is welcome.
Old Aug 18, 2011 | 11:01 AM
sringer's Avatar
well i cant seem to find this info anywhere...so lets just clarify something here. are you manual or automatic?
edit. i assume stick shift becuse you have 3.21?
Old Aug 18, 2011 | 11:03 AM
orfanidisnikolaos's Avatar
You will need a new front carrier.
Old Aug 18, 2011 | 11:35 AM
Bustabizz's Avatar
Former Member
4.10's are fine for 33's. You will need a front carrier for 3.73 and up.
Old Aug 18, 2011 | 12:34 PM
Wandell's Avatar
Loved
If you are gonna spend the money to regear, I'd go steeper than 4.10's. The JK's are geard way to high, especially the heavier JKU's.
Old Aug 18, 2011 | 03:01 PM
nthinuf's Avatar
Stickied right at the top of this Modified area are some Faq's. Open the Drivetrain section and plug some numbers into the chart. Rember to use the actual measured tire height and not the mfg's spec/sidewall height.
People are posting that 4.56's are still hard to find, nationwide backorder or something, so you may be stuck getting 4.10's.
If that is the case, see if you can find a set of used axles off of a rubicon instead of re-gearing your current axles.
Old Aug 18, 2011 | 03:10 PM
shaggy591a's Avatar
Veteran: Navy
4.10 is good for 33in tires. I regeared to that from 3.21s.
Old Aug 19, 2011 | 03:36 AM
Mopahls's Avatar
Yea it's the 6 speed
Old Aug 19, 2011 | 03:37 AM
Mopahls's Avatar
Thanks for the update on the carrier. I will have to keep an eye out on this forum on finding a new one. I might go with 4.56 just as a safe measure / to future proof any other projects.
Old Aug 19, 2011 | 05:40 AM
Goranothos's Avatar
I went to 4.88 and I'm glad I did (manual transmission).
