Need new brake pads, shocks, differential/transfer case fluid
Old Aug 18, 2011 | 07:41 PM
Rubiguy24's Avatar
Question Need new brake pads, shocks, differential/transfer case fluid
Had my 30,000 mile service done last year but the transfer case and differential fluid was not replaced. Went off roading this week so I definitely think I should change it. I have about 34,000 miles on my Jeep right now. Also my brake pads are getting pretty worn out. Need new ones. Just looking for suggestions as to what differential fluid and transfer case fluid to buy and what brake pads.
My stock Rubicon Shocks are cracking, rusting and pretty worn out. I have a 2.5" Teraflex Spacer lift on my Jeep. What shocks would you recommend? I'm looking for real good quality shocks that will last me a long time and have great offroad/road performance.
Old Aug 18, 2011 | 08:00 PM
JdTms11's Avatar
i didn't change my transfer case till 60,000. the diffs i do almost every other oil change, only because there is lots of mud and water up where i wheel. any quality 75w90 gear oil like coastal or Valvoline will work. Ive used the expensive stuff too but since i change it so often now there is no reason to spend the cash on super high quality stuff
for shocks ive been running the teraflex 9550's and like them, rides fairly well
Old Aug 19, 2011 | 01:04 AM
EzK's Avatar
EzK
I don't have much shock experience but I can tell you to get good ones or you will be very unhappy.
As for the t case, its no rush to change but it's easy and just takes some ATF. Since you change your diffs alot I'd keep getting regular valvoline. That's all I've ever used in an axle and never had an axle related problem if any kind, even leaving it in there for basically the life of the vehicle.
