4 inch super lift
Old Aug 30, 2011 | 06:17 AM
jaynasty10's Avatar
Default 4 inch super lift
Going bigger as of now I have a 2.5 RC bb. I'm looking at the superlift 4 inch. anyone running it if so I've got a couple questions to ask you.
Old Aug 30, 2011 | 06:21 AM
wayoflife's Avatar
JK-Forum Founder
if you get this kit, you should be sure to add a set of adjustable front lower control arms so that you can set your caster. also, you should consider getting a track bar relocation bracket and dropped pitman arm or draglink flip kit as with this much lift, you will have some bump steer issues without it. also, if you have a 2-door, you need to keep in mind that at this height, you will need to replace your rear drive shaft with a u-joint style one sooner than later and, you will definitely need a set of adjustable rear upper control arms to do this. if you have an automatic, you will want a new front shaft as well as the factory one is too big in diameter and will make contact with the lip of you tranny pan and this will cause it to tear its boot.
Old Aug 30, 2011 | 07:14 AM
jaynasty10's Avatar
Thanks for the reply. I've got an 08 unlimited automatic. Is there another 4 inch lift that I would be better off going with? I'm not really in the price range for a teraflex but I do want a 4 inch. Not looking to replace either drive shaft either but I will be willing to add control arms
Old Aug 30, 2011 | 07:19 AM
jaynasty10's Avatar
And I should add that it is 99.95% for on road use. Looks more than anything.
Old Aug 30, 2011 | 07:38 AM
fadeout's Avatar
If its just for looks and on road use why not just get a 2.5 coil and throw some 1.5 coil spacers on top, notch the skid below the front driveshaft with a grinder so that it doesn't hit and add lower lower control arms and be done with it. It'll be a lot cheaper and work for what you're going for.
Old Aug 30, 2011 | 05:45 PM
jaynasty10's Avatar
I would rather just get a 4 inch lift. Not just add stuff together. Anything on Rancho 4 inch?
Old Aug 30, 2011 | 05:48 PM
dillUSMC's Avatar
go TERAFLEX, theyre 4in lifts are kinda pricey but i have a TF 2.5" lift and u cant beat theyre quality and from what ive heard the customer support is awesome,
Old Aug 30, 2011 | 06:11 PM
codymitt's Avatar
Yep! On it and love it! Only $540 after the rebate. It includes the pitman arm drop and the track bar relocation.
Old Aug 30, 2011 | 06:14 PM
codymitt's Avatar
Oh and only one more day to take advantage for that awesome discount.
Old Aug 30, 2011 | 06:20 PM
mkjeep's Avatar
I sold my Superlift, went Teraflex, much happier.
