My Jeep Caught on Fire Today
Old Sep 9, 2011 | 08:46 AM
Rubicon09's Avatar
Default My Jeep Caught on Fire Today
I was just driving down the interstate and my stereo shut off. Then the check engine light came on. I went to hit the brakes to pull over and there weren't any. Finally got it slowed down and there was smoke pouring out from under the hood. I grabbed my fire extinguisher and jumped out. Opened the hood and the fire was just behind the intake up against the fire wall. Got that put out and realized the brake controller for the abs that's on the drivers side was smoking like crazy. I ended up pulling the negative batter cable off and that made that quit smoking. Has anyone ever heard of anything like this happening before. It took me by surprise. My Jeep is a 6-speed Rubicon w/ 23,xxx miles on it. Thanks, Nick
Old Sep 9, 2011 | 08:56 AM
Mikey214's Avatar
Sorry to hear about this :/ how much damage? Pictures ? What year ? I know there is a recall on my 2010 on the transmission cooling lines, and I've heard from this forum if they leak it can spark a fire if it gets on anything hot . . . Hope someone chimes in with more information then I can provide !
Old Sep 9, 2011 | 09:01 AM
Rubicon09's Avatar
There wasn't a tremendous amount of damage. I got it out pretty fast. Mostly just melted some of the wiring and the ABS Controller. It's a 2009
Old Sep 9, 2011 | 09:15 AM
NH-JK's Avatar
I hope you have insurance or some type of coverage. I can only imagine the smile on the dealers face when you say fix all this melted electrical $hit.... Cha Ching. $80.00 an hour for "electrical" work. I hope you get taken care of. Sorry for your troubles and good luck.
Old Sep 9, 2011 | 09:18 AM
Ryan0260's Avatar
Man that sucks! Glad you are ok. You need to document this with chrysler. Your situation could have turned out bad. Add another issue with these jeeps...
Old Sep 9, 2011 | 09:20 AM
08HokieJK's Avatar
Man sorry to hear this. Glad you're ok though.
Old Sep 9, 2011 | 09:41 AM
Yankee's Avatar
Have not read anything like that happening in my time on this forum. If there were no combustable fluid leaks back there, it was caused by an electrical short circuit?
Maybe something to do with the brake system controller?
Had you added any wiring through those bundles of wires, like for lights, trailer brake controller, compressor, etc? Anything that could cause chaffing or a short?
Good thing you had fire supression handy.
Rubicon09's Avatar
This should hopefully be covered under warranty.
I have a call into Chryslers fire claims division.
Old Sep 9, 2011 | 09:44 AM
Rubicon09's Avatar
Originally Posted by Yankee
Have not read anything like that happening in my time on this forum. If there were no combustable fluid leaks back there, sounds like it was electrical fire. Maybe something to do with the brake system?
Had you added any wiring through those bundles of wires, like for lights, trailer brake controller, compressor, etc? Anything that could cause chaffing and a dead short?
I have lights on the Jeep but the wiring wasn't run near the fire. None of the wiring I added was hot. Just the factory wiring.
Very glad I had a fire extinguisher. It would have burned up.
Old Sep 9, 2011 | 09:56 AM
nicker22's Avatar
as long as you haven't modded anything with that it should be covered under factory warranty. IF NOT ID BE F-ING PISSED!
main thing is your ok and secondly the jeep is not badly damaged.
