Gears
Old Nov 10, 2011 | 04:15 PM
Schwheelz's Avatar
Default Gears
Hey guys I am curious to know whether or not I need a new driveshaft when I change gears? I'm looking at the 5.13 kit for the dana 30/44 on rough country and it's not very specific
Old Nov 10, 2011 | 04:21 PM
JandS08JKU's Avatar
only if you've lifted it beyond the angles the stock shaft can handle. I have 5.13's and an auto w/35's. kinda wishing i would have gone 4.88's. the majority of driving is on the freeway/hyway. were running about 2300ish rpms at 70. also i would check out northridge4x4 they have some amazing deals on gear packages. and free shipping right not too
Old Nov 10, 2011 | 04:31 PM
Schwheelz's Avatar
Thanks for the heads up, I'm planning on running 37's if everything goes right with trails maybe once a month if I'm lucky. I heard 5.13 was a good setup for this?
Old Nov 10, 2011 | 04:33 PM
scooby snacks's Avatar
5.13's will let you go up to 37's no problem...
Old Nov 10, 2011 | 04:38 PM
Kevin123's Avatar
I just bought the 4.88 Yukon gears with the Install kits shipped to me for $525.00 from Northridge 4x4.
Old Nov 10, 2011 | 04:52 PM
nthinuf's Avatar
Originally Posted by ECHO
I agree... Consider your driving habits before you pick your gears.. it makes a big difference
x3
Also consider which transmission you are getting advice for, since the gearing needs for a 6spd are different than the gearing needs for an auto. Measuring your tires and plugging some numbers into the rpm chart in the faq's would be a good place to start. At least you'll have some context when reading peoples reviews.
Old Nov 10, 2011 | 05:05 PM
Southern Girl's Avatar
Originally Posted by nthinuf
x3
x4 and good luck!
