34inch tires question
Old Nov 11, 2011 | 12:12 PM
Tanman823's Avatar
Default 34inch tires question
Hey everyone. Just had a quick question to see if anyone has had and experiance with the matter. I found someone locally that's selling micky t's 34 inch baja for a pretty good price. I know a stock jeep can fit 33s no problem... I swapped the flairs for the bushwacker flat fenders and i see I did gain clearance but i dont know if i am missing something (spacing wise) ill post up a before and after Adding the flairs
Old Nov 11, 2011 | 12:13 PM
Tanman823's Avatar
This is with them installed
Old Nov 11, 2011 | 12:16 PM
scotty6336's Avatar
I'd say you'll be fine. Go find something to flex-test it on with the swaybar disco'd and you'll find out.
Old Nov 11, 2011 | 12:23 PM
Tanman823's Avatar
Cool thanks for the quick reply. I was just worried there was gonna be rubbing issues. It's not like I'm going to be doing heavy Offroading until I fully get my lift this winter or spring
Old Nov 11, 2011 | 12:27 PM
scotty6336's Avatar
You'll be ok.
My 35's measure to 33.9, I put them on bone stock and drove around for a few weeks, they'd rub the flares, so I cut the flares.
Then when flexing pretty hard the'd come up and hit the pinch weld in the rear or the top side of the fender in the front, so I added a 1/34" 175 dollar daystar spacer, no more rubbing, and all this was with NO bumpstops.
Old Nov 11, 2011 | 12:28 PM
scotty6336's Avatar
One more thing, they'll be rubbing (at full steering lock) the plastic shield that hangs from the bumper...My 2C's, take it off and throw it away.
Old Nov 11, 2011 | 12:33 PM
Tanman823's Avatar
Awesome i might have to grab this deal then
Old Nov 11, 2011 | 12:36 PM
scotty6336's Avatar
Originally Posted by ludski
should be able to fit them. worst comes to worst, you cut the pinch seam in back a little. but itll fit.
youll need some spidertrax spacers though. or your front tires will rub the frame.
^^In regards to this, and I forgot to ask, what wheels are they going on? a/m? your factory ones?
Either way, just get em, put em on and see what happens. Hell if they contact the rails just don't turn your wheel all the way until you get some spacers
Old Nov 11, 2011 | 12:47 PM
Ryan0260's Avatar
With the flats and some spacers you should be good for normal driving
Old Nov 11, 2011 | 12:55 PM
Tanman823's Avatar
I'm just running stock rims for the time being. I'm in a position where i cant afford rims and lift but need new rubber
