Rear drive shaft rubs gas tank skid
Looking for a fix. I have a 4 door Jk with 4" Rancho long arm running 35's and 1350 drive
Shafts. The diff is dead nuts center.
When rear drivers tire drops and passenger is stuffed my drive shaft is rubbing the fuel tank
Skid pretty good.
Skid pretty good.
is it safe to assume you have a pinion flange installed? if so, changing that over to a yoke will help clear your gas tank. you can also purposefully shift your axle over a bit to help clear it too.
