Pro cal
Old Nov 12, 2011 | 01:44 PM
Apwjk518's Avatar
Default Pro cal
Have seen a few posts on it. Can someone tell me how it works and where I can find it. Tks
Old Nov 12, 2011 | 02:00 PM
nthinuf's Avatar
It is a small programmer with a bunch of little dipswitches. It will come with a card that tells you how to set the switches for each function you want. up-up-dn-dn-dn-dn-up-up, or whatever. Once you get it set, you plug it into the port by your left knee.
You can get t through any local 4wd shop, or any of the online vendors.
Old Nov 12, 2011 | 02:05 PM
Tiburon's Avatar
If you get larger tires you can reprogram your computer to adjust the speedometer and shift points. You can adjust or turn off your TPMS, you can adjust computer if you install larger gears, you can turn on/off momentary turn signals, you can adjust accelerator pedal, you can use it to re-center steering wheel. Might be one or two other things you can do with it be I don't recall right now.
Old Nov 12, 2011 | 02:07 PM
Apwjk518's Avatar
Thanks, will pick one up!
Old Nov 12, 2011 | 04:26 PM
ThreadHijacker's Avatar
Does it work on a 2012?
Old Nov 12, 2011 | 05:06 PM
Freewill's Avatar
Pro-cal will also set the idle speed up for more alternator output while winching.
Old Nov 12, 2011 | 05:59 PM
Locko's Avatar
From: Hawai'i, Miami , FL, Alaska, Tennesse..S America
watch the video !!! works for 2012
htt p://www.aev-conversions.com/news/?p=192"]http://www.aev-conversions.com/news/?p=192
Old Nov 12, 2011 | 06:52 PM
JKCloak's Avatar
How much does one of these little fella's usually go for? :dollars:
Old Nov 12, 2011 | 07:43 PM
AREA 13's Avatar
Default Pro-Calc
Damit! I really have to stay off this web site! I just watched the video (Thanks LOCKO!) and just bought the Pro-calc. Wasn't something I was going to buy, until I watched the video and heard him state the price and the features it gives you... Kinda was a little disappointed when I went to AEV's website, because the Pro-Calc is now 149.00 not 129.00. But I figure if it changes the shift points by resetting my tire size and gaining better fuel economy, I guess it will be worth it.
Jeff
Old Nov 13, 2011 | 03:12 AM
RedJK2's Avatar
The ProCal is going to be right at $150 no matter where you buy it. I went with a vender who shipped the fastest and for free.
