Code problem
Just was driving an had the traction control come on an stay on which I'm guessing is a code... I tried the key trick( turn 3 times an display the code) but all it show is a bunch of dashes the says done an beeps twice... I have the pro cal too didnt know if this would help at all? Any suggestion or help would be much appreciated....
Thanks guys
Thanks guys
more than likely, your steering wheel is off center just a bit. if you have a procal, you can use it to recenter your steering wheel and, after the computer is cleared out, it will keep it from coming on again.
