17x9 wheel and tire question
Old Nov 21, 2011 | 05:45 PM
Kiko160's Avatar
Default 17x9 wheel and tire question
Hope someone has some input for me...I just picked up a set of 17x9 rims (found them on craigslist) for a good price, I've sanded them down and primed and will be painting soon. I wanted to put M/T 33x12.5x17 on the rims and was told that with no lift I would need at least 1.5" spacers...does anyone know if this is true? I wanted to leave suspension stock and maybe just get coil spacers or a leveling kit to make it look good...
So if anyone knows would the tires fit? Will I need the spacers??
Thanks
Old Nov 21, 2011 | 05:47 PM
jsears's Avatar
Thanks
Are they stock Jeep wheels? Do you know the back spacing on them?
Old Nov 21, 2011 | 05:52 PM
Kiko160's Avatar
Not sure what the back spacing if any?? Is there a way to measure or could I google it???
Old Nov 21, 2011 | 05:54 PM
jsears's Avatar
Rubi wheels have 6.25'' back spacing.
Your answers will be answered here:
https://www.jk-forum.com/forums/show...274#post211274
Old Nov 21, 2011 | 05:59 PM
roadking54's Avatar
Check out this link for backspacing info.
Those look like stock wheels of some sort...do they have the correct 5x5 bolt pattern for the JK? They look to have similar backspacing of the stock rims of 6" or so...and you'll want more like 4.5". Are they really 9" wide?
Old Nov 21, 2011 | 07:10 PM
CerOf's Avatar
Those look like stock Rubicon rims. If so, they are only 7.5" wide and have backspacing of about 6".
You will rub off road with anything much wider than a 265 width when flexed and turning.. Spacers are recommended.
