OME HD Lift ---Add Leveling Spacers?
I will be installing an OME 2.5" lift with HD springs this weekend (Bought from NorthRidge!)
I have the RR XHD bumper with RRC Mount and Smitty 10k Winch on the front, still no rear bumper although I will have a 35" Tire/Wheel back there soon... Eventually a Rear bumper/Carrier will be added...
The question: Should I order a small spacer set for the front to make it level, if so what size spacer?
Thanks!
Thanks!
I have the OME HD springs and when I installed them I had LoD front bumper, winch, steel winch cable, dual batteries(die hard marines), AEV hood. That was a lot of weigh in the front, but the only weight I had on the back was the 33" spare and it had a pretty good rake. When I installed the rear bumper and spare carrier it evened out. Now it sits perfectly even with zero rake.
