RK 2.5 Max Travel install questions
Old Nov 30, 2011 | 03:58 PM
troyboy's Avatar
Default RK 2.5 Max Travel install questions
I should be getting my kit any day now and was reading the instructions on-line. I notice that the measurements for the LCAs and the front track bar are in the instructions.
Has anyone who has installed this kit had to re-adjust those measurements or are they bang on?
Also, when disconnecting the brake line, how fast does the fluid drain out? Should I be capping the line or is it just a slow drip?
Old Nov 30, 2011 | 04:21 PM
20JK10's Avatar
The measurements are close, but you will have to fine adjust it for your vehicle.
Here's a good write-up on how to adjust your track bar under "re-centering your front axle"
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Nov 30, 2011 | 05:06 PM
tslewisz's Avatar
The calipers will dump a bunch and the lines will empty if you let them hang. Zip tie them up.
Old Nov 30, 2011 | 10:18 PM
troyboy's Avatar
Thanks guys!
