Newb lift question.
Old Dec 1, 2011 | 05:38 PM
MNYTIME's Avatar
Default Newb lift question.
Hoping someone can help me. 2011 4dr jk sport auto. Bought OME spring/shock 2 inch kit. Was a little surprised it comes with just that...and some weird looking bracket thing....a few questions, what is the bracket thing for? Do I need a front or rear track bar? Do I need a steering stabilizer? If so on the prior 2questions, any suggestions? Btw, right now stock 17 rims and stock tires, will be going to 17 rims, and 33x12.5.
Old Dec 1, 2011 | 05:40 PM
Cdyspeed's Avatar
can you post a picture of the bracket?
your stock steering stabilizer will be fine
Old Dec 1, 2011 | 05:57 PM
MNYTIME's Avatar
It's called the panhard extension bracket and bump stop kit...sorry I don't have a pic. But this link shows it....
ht tp://www.knowwhere2jeep.com/specials/old-man-emu-3-suspension-lift-for-jk-2-door-with-heavy-load.html
Old Dec 1, 2011 | 06:07 PM
StrizzyChris's Avatar
If its like you asked then its just that, a bump stop extension. They are used to prevent your shock from bottoming out at full articulation and put that load on the bump stop.
Old Dec 1, 2011 | 06:15 PM
MNYTIME's Avatar
So just swapping the shocks n springs and adding the stops and I'm done?
Old Dec 1, 2011 | 06:28 PM
tcdawg's Avatar
From the pictures it looks like rear bump stop extensions only, the kind the bold to the axle.
Old Dec 1, 2011 | 06:33 PM
MNYTIME's Avatar
Yes, and theres this panhard thing in there too....but I don't know what it's for,,,,no directions for this.
Old Dec 1, 2011 | 06:43 PM
Robar's Avatar
The panhard "thing" is a track bar drop bracket. It's used to lower and level the track bar and center the axle.
Old Dec 1, 2011 | 06:55 PM
MNYTIME's Avatar
Lol, gotcha...forgive the ignorance...."thing". Do i need it, or should I not?
Old Dec 1, 2011 | 07:02 PM
CarlWooten's Avatar
I just installed my OME kit with the panhard extension a few weeks ago. Without the panhard my rear axle was off center almost 3/4 of an inch. It was visible if you were looking for it. Installing it will center you rear axle under your body. The bump stops prevent the trac bar from hitting your shocks at full articulation. At least that's what the instructions said. Anyways it was very easy to install, took about an hour. You just need a drill and some basic hand tools.
