EVO Draglink flip kit-Anyone have picks of it installed?
Old Dec 7, 2011 | 07:56 AM
Cold's Avatar
Default EVO Draglink flip kit-Anyone have picks of it installed?
Thanks
Robert
Old Feb 10, 2012 | 02:54 PM
Nkapalski's Avatar
I just put mine in and it fixed everything!Click image for larger version
Old Feb 10, 2012 | 03:05 PM
RubiconRod's Avatar
Originally Posted by Nkapalski
I just put mine in and it fixed everything!<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=276426"/>
Mine is in the garage. Haven't had time to install it. Have any issues?
Old Feb 10, 2012 | 03:07 PM
Rich6700's Avatar
I just put mine in and it fixed everything!Attachment 276426
What did it fix? just out of curiosity.
Old Feb 11, 2012 | 04:36 PM
Nkapalski's Avatar
I was having bump steer issues leading to death wobble at low speeds when I hit potholes on gradual turns. Prior to doing this kit I tried everything. Went through planmans' entire write up. torque, changed bolts checked everything and it still persisted. put this kit on and no more problems.
As for installation issues it was pretty simple. Used a battery powered drill to drill the out for the bushing. Have an extra set of hands to feed it cutting out, will go a lot easier. There is another hole that needs to be drilled, you might need to remove the passenger side brake rotor if you don't have an angle drill.
Good luck!
Old Feb 11, 2012 | 05:10 PM
Deere_Jeep's Avatar
Mine's sitting in the garage too. I probably won't get it on for 3 or so weeks. Please post up if you have a write up or tips.
Old Feb 11, 2012 | 05:11 PM
Tanner6427's Avatar
I put mine on about a year ago, it fixed the geometry once you go over 3" of lift. I'll post pics in the AM
Old Feb 11, 2012 | 05:12 PM
Tanner6427's Avatar
Here's a pic for you
Old Feb 11, 2012 | 05:13 PM
Deere_Jeep's Avatar
Welded anyone? or bolted on?
Old Feb 11, 2012 | 05:37 PM
Nkapalski's Avatar
Bolted on and torqued. I'll see how it holds up before welding
