Tire clearance
Old Dec 8, 2011 | 03:35 AM
JJsno21's Avatar
Default Tire clearance
I just bought a 07 unlimited x and was wondering if I bought the BW Flat Flares could I fit 33's on stock suspension. I don't plan on doing much off roading just maybe mudding occasionally. I'm not really looking to spend that much so can someone tell me if I'll get enough clearance with the flares to put on 33's
Old Dec 8, 2011 | 03:51 AM
Robar's Avatar
You can probably do 33" tires w/o any lift or flat flares.
WHEELS & TIRES
Old Dec 8, 2011 | 03:53 AM
holmes4x4's Avatar
yeah you have enough clearence
Old Dec 8, 2011 | 04:26 AM
CerOf's Avatar
WHEELS & TIRES
No lift + width wider than stock = rub.
Old Dec 8, 2011 | 05:24 AM
CarlWooten's Avatar
I've seen stock JK's running 33's. It's only another 1/2 inch of tire from the stock 32 inch tire. Just don't go much wider than stock.
Old Dec 8, 2011 | 05:57 AM
Doc Highway's Avatar
I think with the flat flares you would be fine. I know people are having rub issues with extra width on the stock flares, but they extend down further.
Old Dec 8, 2011 | 07:37 AM
revvinkevin's Avatar
Really fine with the flat fenders, with a little trimming 35s are possible.
Old Dec 8, 2011 | 08:24 AM
jesse0376's Avatar
You could go with a leveling kit would be alot cheaper then buying aftermarket fenders unless you cut yours. This is my jeep when I had 33s and a leveling kit.
ID:	247246   Click image for larger version
Old Dec 8, 2011 | 10:41 AM
OrlJeep's Avatar
A buddy if mine at work runs 33's on his JKU. No lift, stock flares, no problems.
Old Dec 8, 2011 | 01:02 PM
CerOf's Avatar
Does he disconnect offroad?
My photo is with a leveling kit and I tore a piece of plastic off and would have torn my flare off if I turned. Connected, it might not rub.
The width is the issue with a 33" tire.
Flat fenders, increased bumpstops, ot cut flares will prevent the rub.
