Evo suspension question.
Hello I am looking into the evo double throwdown kit and I am confused by something. It stats that is has 14" of vertical travel. Could someone explain that to me a little more as I would think the system would travel more.
EVO
it means the shocks will allow for 14" of travel. in other words, the amount your axles can articulate when flexing on the trail is a lot!
Originally Posted by Andrew@EVOMFG
The EVO DTD systems give 14" of vertical wheel travel. Most standard coil and spring lift kits yeild around 8"-9" of usable vertical wheel travel. Therefore 60%-75% improvement over a standard lift kit.
EVO
Whytiptoe EVO DTD will not let you down and the travel you will get is nothing less than amazing.
Chris
